Certificate Monitor
User Manual
SoftPerfect Certificate Monitor is a free desktop application that keeps an eye on the TLS/SSL certificates behind the hosts you care about, so an expired or misconfigured certificate never takes you by surprise. It periodically connects to each host, retrieves the certificate and its full chain, and sums up its health with a letter grade from A to F. It works with ordinary domain names and with bare IP addresses, including the modern short-lived certificates now issued for IP addresses. Everything runs on your own computer — your host list and certificate details never leave your machine.
To begin, click Add Host on the toolbar.
Certificate Monitor start window
Certificate Monitor main window before any hosts have been added.
The address can be a domain name (such as example.com) or an IP address (such as 203.0.113.10). Besides the common TLS ports in the list, you can type any other port, which the list then shows as Custom. Mail servers on ports 25 and 587 start in plain text and switch to TLS on request (STARTTLS); Certificate Monitor does this for you, so their certificates are checked like any other.
Add Host dialogue
Adding a host for monitoring.
A new host is checked straight away. All hosts are then rechecked at the interval set in Settings, or every 24 hours by default.
To add multiple hosts at once, use the menu File → Import Hosts with a text or CSV file listing one host per line: the address (example.com, example.com:8443, [2001:db8::1]:8443, or a web address), optionally followed by a comma, tab or semicolon, and a display name. Hosts already in the list are skipped. To move everything to another computer, including settings and history, use the menu File → Export Configuration on the source machine and then Import Configuration on the destination.
Main window
Table view with the certificate details panel and the status line.
Table view
The Expires column turns amber, then red, as expiry draws near.
The Status column shows one of the following:
  • Valid,
  • Expiring Soon,
  • Expired,
  • Chain Error (the chain does not lead to a trusted root),
  • Mismatch (the certificate is for another name),
  • Unreachable, or
  • TLS Error (the host answered but the secure connection failed).
The icon beside each name shows the state at a glance; View → Legend explains each one.
Sorting by Grade can conveniently bring everything that needs attention to the top. The filter box can match names, addresses, certificate subjects and statuses.
Tile view
Tiles offer an at-a-glance view; their size can be set in Settings. Large-size tiles additionally show the address and status.
Tile view
Tile view with medium-size tiles and the details panel hidden.
Details panel
The Details panel shows information about the selected host on two tabs:
  • Certificate tab displays the certificate's fields, the TLS version and cipher of the connection, and the chain from the root to the host's own certificate. If a server sends its certificate without the intermediate, the chain is completed the way browsers do it, by fetching the missing certificate from the address given in the certificate. For a certificate issued to a bare IP address, which carries no common name, the IP address is shown in place of the name.
  • History tab displays past checks, with each renewal (a new serial number) and each change of status, so you can see when the certificate was last replaced.
Status line
Click a specific count in the status line to show only those hosts in the table or tiles; click it again to show them all.
Grades
Each host is given a letter grade summarising its certificate health. The grade starts from the TLS version the host negotiates — A for TLS 1.3, B for TLS 1.2, C for TLS 1.1 and D for TLS 1.0 — and is then held down by anything that weakens it:
  • At most B: a self-signed certificate, or a server that sends its certificate without the intermediate, which browsers fetch for themselves but many other clients do not.
  • At most C: a weak key (RSA under 2048 bits, EC under 256 bits) or a weak signature (SHA-1, MD5).
  • One or two grades lower: a certificate approaching the end of its validity; the closer it is to expiry, the lower the grade.
  • F: the certificate has expired, its chain does not lead to a trusted root, or it does not match the host name. In its final days a certificate also drops to F.
A host that cannot be reached, or whose secure connection fails, shows no grade until a check succeeds.
How “expiring soon” is judged. Rather than counting down from a fixed number of days, Certificate Monitor scales its expiry warnings to each certificate's own lifetime. A conventional year-long or 90-day certificate is flagged in roughly its final month. A short-lived certificate, such as a Let’s Encrypt six-day certificate for an IP address, is only flagged in its final day or so, close to when its automatic renewal is due. With this approach, a healthy certificate designed to be replaced every few days can earn an A grade and is not perpetually marked as expiring.
Common scenarios
never miss a renewal
You look after a handful of public websites, and the last thing you want is an outage because a certificate quietly lapsed over a weekend. Add each site by its hostname, leave Certificate Monitor running, and let the grades keep watch. Healthy hosts sit at a green A grade; as a certificate nears the end of its life, its grade goes down and a desktop notification alerts you while there is still plenty of time to renew. A glance at the list or the alert is all it takes.
monitor a short-lived certificate
Certificates are getting shorter, and Let’s Encrypt now issues six-day certificates for bare IP addresses. Point Certificate Monitor at the address, for example 203.0.113.10 on port 443, and it reads the certificate straight from the IP, showing the address where a name would normally go. Because the warnings scale to each certificate's lifetime, that freshly issued six-day certificate still grades A and is only flagged in its final day, right when its automatic renewal is due, instead of being marked as expiring the moment you add it.
audit a portfolio of domains
Inherited a stack of servers and not sure which certificates have a problem? Simply add them all, switch to the Table view and sort by Grade. The weakest configurations float to the top. An untrusted chain, an outdated TLS version, a certificate that does not match its host, or one about to lapse each brings the grade down, so a single sorted column shows you exactly where to direct your attention. Open the Details panel on any host to see the full chain and the reasons behind its grade.
Settings
General
Certificate Monitor, General settings
General settings: startup, check interval and data retention.
Minimise to tray
Closing the window leaves the application running in the system tray, where it continues checking.
Timeout
How long to wait for each step of a connection before the host counts as unreachable.
Data retention
Check history older than the set period is deleted automatically.
Notifications
Certificate Monitor, Notification settings
Notification settings: desktop alerts for certificate events.
Certificate expiring soon
Expiry notifications are timed in proportion to the certificate's lifetime, so you are alerted in good time whether it lives for a year or just a few days.
Connection errors
The host could not be reached, or the TLS handshake failed.
Host recovery
A host that had an error is valid again.
Appearance
Certificate Monitor, Appearance settings
Appearance settings: tile size, theme and colour scheme.
The theme can be chosen on Windows; on macOS and Linux the application follows the system. The colour scheme applies to the tiles.
GRANT OF LICENCE
This software is FREEWARE. Permission is hereby granted to anyone to install, use, copy, publish, and distribute copies of this software free of charge, provided that the original software is not modified in any way.
MODIFICATIONS
USE
This software is distributed “as is”. No warranty of any kind is expressed or implied. You use it at your own risk. In no event shall SoftPerfect or its agents be liable for any loss or inaccuracy of data, loss or interruption of use, or cost of procuring substitute technology, goods or services, or any other loss or damages. If, despite the foregoing, SoftPerfect is found liable for any damages, its total cumulative liability shall not exceed AUD 1 (one Australian dollar).
TERMS OF ACCEPTANCE
Product Page & Download
