Remote SNMP
SNMP (Simple Network Management Protocol) is widely supported by routers, switches, printers, UPS devices and many other network equipment. Choose Options → Remote SNMP from the menu.
The dialog shows four columns: Item Name, Community/User, Version and MIB OID. When creating a new entry, select the SNMP version:
- Windows built-in: uses the operating system’s SNMP implementation.
- SNMPv1, SNMPv2c: community-based authentication. Enter one or more community strings separated by commas.
- SNMPv3: secure authentication with username, auth password and privacy password.
The string display mode can be set to Automatic detection, ASCII or HEX.
There is a built-in MIB browser for easy selection of OIDs. The browser shows the standard MIB tree and a symbolic path for the selected OID. You can add custom MIB files to %APPDATA%\SoftPerfect Network Scanner\MIBs.
OIDs may contain the variable parts %0 and %1. The former is replaced with the octets of the scanned IP address, and the latter with the octets of the scanned MAC address. For example, the OID 1.3.6.1.2.1.4.20.1.3.%0 can be used to extract a device’s network mask.
Most network printers expose toner levels via SNMP. Create an SNMP query with the OID for the toner level (commonly under 1.3.6.1.2.1.43.11.1.1.9) using SNMPv2c with community public. After scanning, the column will show the remaining toner on each printer.
